How to use current system time in Python shutdown script?
  • Mar 11, 2016 1:32 AM UTC
  • 95 views
dbCursor.execute("""INSERT INTO FME_LOG(NAME, RUN_DATE) VALUES ('eee', datetime.datetime.now())""") is not working.
Best answer by david_r
Hi
If it's Oracle, you can use the built-in SYSDATE function to return the current timestamp without having to wrestle with Python datetime objects:
insert into fme_log(name, run_date) values ('eee', sysdate)
The equivalent to SYSDATE on MS SQL Server is "sysdatetime()" and on PostgreSQL it is "current_timestamp".
David
  • Mar 11, 2016 8:22 AM UTC
Hi
David
Forum|alt.badge.img+5
  • Mar 11, 2016 10:57 AM UTC
Hi
David
Note that sysdate is the timestamp of the database server. This might be different from the timestamp of the client where you're running FME, which is the timestamp Python would give you. Sysdate is probably the one you want though.
