How can I programmatically get the FME Registration Key or Machine Code?
fmelizard
Forum|alt.badge.img+19
For my workflow, I need to expose this value in an attribute. What are my options?
rylanatsafe
Forum|alt.badge.img+13
One of our customers identified that this is possible using FMEObjects and Python:
import fmeobjects
lm = fmeobjects.FMELicenseManager()
print lm.getLicenseProperty('MACHINE CODE')
import fmeobjects
This seems to work on FME Desktop with a fixed license.   If using a floating license or on FME Server then "MACHINE CODE" is not defined.
Any suggestions on how to do this when using a floating license and/or on Server?
rylanatsafe
Hi @neilhellas​ , for FME Server you can use the authenticated REST API endpoint:
/fmerest/v3/licensing/machinekey
I'll share your question regarding the floating license with my colleagues and hopefully we can find an answer for you!
rylanatsafe
For FME Desktop, you can use the following command—which could be used with the SystemCaller transformer—to retrieve the value:
<path_to>/fme.exe MACHINE_KEY
This command simply returns the machine key (e.g. 1-234-567-890).
