Hi, we're moving our web services to Tomcat on a different host (don't ask). In the documentation. When do I Edit the services within the web interface?
  • Feb 3, 2022 1:53 PM UTC
  • 38 views
rm_sam
We are using Tomcat, installed by itself, on the FME server on port 80. DB server is a separate Oracle Server. I need to move the web service to Tomcat on a different server, to port 80. In the documentation, it says to 1) modify the web server url in fmeserverconfig.txt, then 2) edit the services in the web interface.  I assume step 2 should be a step 3, and step 2 would be to start up Tomcat, Core, Server, DB, on the servers, allowing the war files to build, correct? Thanks for any help.
Moving the Web Applications Server to Another Machine (safe.com)
itsmatt
Forum|alt.badge.img+48
  • Feb 17, 2022 12:48 PM UTC
Haha, yeah I think so - hard to access the user interface is the service isn't even running. did you fix it?
