Trying to connect a Smallworld db for the first time.
When I hit on the ... next to "Table List" then it keeps loading.
Are there settings I should check and can I find some logging somewhere?
Capture
The listener was trying to describe an external table (Oracle). After excluding these tables the problem was solved.
