FME Server on Linux64
  • Apr 30, 2013 7:20 AM UTC
  • 44 views
Hi, are there any plans to increase the number of formats supported on LINUX 64 server ?
  • Apr 30, 2013 11:30 AM UTC
is there a particular format that you're thinking about?
Be aware that FME uses 3rd part libraries and/or APIs for some formats (notably those by ESRI), and Safe would effectively depend on the libraries to be adapted for Linux by the format "owners" before they could add support to FME.
Hopefully someone from Safe can chime in with some info regarding their plans for Linux.
David
  • Apr 30, 2013 12:42 PM UTC
The list of supported formats on linux-64 looks to be pretty small
see:http://www.safe.com/fme/format-search/
As far as I can tell many "common" formats are not supported.
Current list is:
Autodesk AutoCAD DWF
Autodesk AutoCAD DWG/DXF
Bentley MicroStation Design (V8)
Comma Separated Value (CSV)
Data File
File Copy
FME Feature Store (FFS)
FME Server Configuration
FME Server Repository
FME Server Stream
FME Server Stream (Attribute)
OS (GB) MasterMap
