FME Options: Where the Default Paths are saved?
  • September 5, 2022
  • 31 views
massizurli
I need that every user who launches FME Workbench has set paths to a shared folder, in order to share connections to databases. However, I do not find where FME saves this information. In the Windws registry?
  • September 5, 2022
I suspect it's saved here:
HKEY_CURRENT_USER\SOFTWARE\Safe Software Inc.\Feature Manipulation Engine\Shared Resource Directory
hkingsbury
Forum|alt.badge.img+55
  • September 7, 2022
There is a key for the resources (as above) and also one for the named connections
[HKEY_CURRENT_USER\SOFTWARE\Safe Software Inc.\Feature Manipulation Engine]
"Shared Resource Directory"="\"\\\\path.local\\SAFE FME\\Shared_Resources\""
[HKEY_CURRENT_USER\SOFTWARE\Safe Software Inc.\Feature Manipulation Engine\Settings]
"Named Connection Directory"="\\\\path.local\\SAFE FME\\Shared_Resources\\Connections"
