FME Flow via Microsoft Entra application proxy
  • May 12, 2025
  • 30 views
kieran.odonnell
Forum|alt.badge.img+4
Hi FME community,
I’ve recently been asked if FME Flow supports access via the Microsoft Entra application proxy. Has anyone configured this and can confirm it is supported?
I believe it’s very similar to the setup explained in the documentation below, but I haven’t been able to find any documentation referencing the Microsoft Entra application proxy.
https://support.safe.com/hc/en-us/articles/25407571916173-Use-a-Reverse-Proxy-with-FME-Server
https://support.safe.com/hc/en-us/articles/25407364847885-Using-IIS-and-ARR-as-a-Reverse-Proxy-in-FME-Flow
Thanks!
hkingsbury
Forum|alt.badge.img+54
  • May 12, 2025
I’ve had success using Azure Frontdoor in front of FME before. Looking at the documentation of Entra AP it looks similar to NGINX, CloudFlare Tunnels, LocalTunnel just with a more robust access/security management.
I’d want to do a good bit of testing to ensure the various components of FME are still talking to each other through it. Also worth doing some checks on websockets (if that’s a required use case)
