FME Flow- File Size Limit
  • March 25, 2024
  • 292 views
couch
Is their a file size limit for loading data into the Resources folder?
When the file reaches a certain size the file fails to load.
Thanks Chris
  • March 25, 2024
What is the error message?
The file format and the reader type used in FME would be helpful to know here. Or if this concerns an upload through the web GUI, just how big is the file, approximately?
couch
  • March 25, 2024
Hi, is any file just dragging into RESOURCE folder via web interface, limit seems be around 20MB. I am told their is enough space on hosting server. Ta
couch
  • March 25, 2024
Just says this but no green tick, and no data
hkingsbury
Forum|alt.badge.img+67
  • March 25, 2024
Have a look through here -
Assuming you’re proxying through IIS, then its just a case of increasing the allowed file size
