FME Flow- File Size Limit
  • Mar 25, 2024 4:42 PM UTC
  • 449 views
couch
Forum|alt.badge.img+7
Is their a file size limit for loading data into the Resources folder?
When the file reaches a certain size the file fails to load.
Thanks Chris
  • Mar 25, 2024 4:48 PM UTC
What is the error message?
The file format and the reader type used in FME would be helpful to know here. Or if this concerns an upload through the web GUI, just how big is the file, approximately?
couch
  • Mar 25, 2024 4:50 PM UTC
Hi, is any file just dragging into RESOURCE folder via web interface, limit seems be around 20MB. I am told their is enough space on hosting server. Ta
couch
  • Mar 25, 2024 4:51 PM UTC
Just says this but no green tick, and no data
hkingsbury
Forum|alt.badge.img+73
  • Mar 25, 2024 6:45 PM UTC
Have a look through here -
Assuming you’re proxying through IIS, then its just a case of increasing the allowed file size
