FME Desktop - Setting a temporary file location for FME
  • October 26, 2020
  • 2115 views
ronan
Hello,
By default, the location of FME temporary files in the system temporary directory is on some Windows versions defaults to C:\\temp or under the user local temp directory (i.e. C:\\Users\\mark\\AppData\\Local\\Temp). There is a way to change the location of temp files using these methods : https://community.safe.com/s/article/fme-temp-environment-variable
The problem is we need administrator rights to make these manipulations. FME users doesn't have always the administration rights. In my case, setting the location right directly from the WorkBench (in the FME options menu for exemple) would be very helpful : Do you think it can be a good idea? Is there any project to ease the setting of FME Temp files in a future version of FME?
Thank a lot
Ronan Jarno
Best answer by david_r
As a workaround, you could test starting FME using a batch file, e.g.
set FME_TEMP=C:\temp\fme
"C:\Program Files\FME\fmeworkbench.exe"
It may or may not work, depending on your security settings.
  • October 26, 2020
ronan
  • October 27, 2020
Thanks a lot, this solution is working , no need of administration rights
