ERROR : Error migrating key storage from jceks file fme_publicKey.jceks
  • May 12, 2023 9:27 PM UTC
  • 0 replies
  • 170 views
Hi!
New to FME and just installed FME Forms on two different machines. One Windows PC - no problem.
The other machine, an Apple Macbook Air M1 gave me some trouble.
I've installed the version 2023.0.0.1 for Apple Silicon.
After starting it and requesting a trial license, the logs give me the following errors:
ERROR : Error migrating key storage from jceks file /Users/sverker/Library/Caches/Safe Software/FME/fme_publicKey.jceks
Error while migrating public encryption key file
Unable to read from file '/Users/sverker/Library/Caches/Safe Software/FME/fme_publicKey.fmeks', No such file or directory (Code 2)
I can't see any Transformers in the FME Hub and I when I go into preferences and the "FME Packages" submenu (or some of the other submenus) I get:
bildI've tried the full removal and reinstall, but the problem persists.
I tried giving the FME Workbench application the Full Disk Access permission.
Thankful for any help!
