Connecting to ESRI portal - Esri ArcGIS Portal(template) missing
  • April 8, 2021
  • 14 views
I am trying to setup a web connection under Tools -> Manage Service -> and I don't have Esri ArcGIS Portal(template) available. Is there a file I can import or resource to build it for Enterprise Portal?
Version of desktop: FME(R) 2018.0.1.0 (20180518 - Build 18310 - WIN64)
rahulsharma
Forum|alt.badge.img+10
Hi @singletrackmap​
You can set up OAuth for ArcGIS Portal, as long the server is set up with SAML authentication.
Please follow this article, to complete the set up.
