connect to FME servers postgres database for statistics.
  • Feb 3, 2020 4:24 PM UTC
  • 38 views
Hello, I have fme server and and engines on two different machines in a distributed environment. I am trying to query the underlying postgres database directly through toad datapoint. It seems I need to connect to port 7082. I have not figured out the server name and location however. DataPoint is on my local box not on fme server.
erik_jan
Forum|alt.badge.img+26
  • Feb 3, 2020 4:29 PM UTC
You can find the connection parameters in the config file: "fmeCommonConfig.txt", that should be in your "FMEServer_home\\Server" folder.
Hope this helps.
