Checking for upgradable transformers in uploaded workspaces?
  • Aug 27, 2025 10:06 AM UTC
  • 155 views
carolina_w
Forum|alt.badge.img+33
Hi everyone,
I was wondering if there’s a smart way to check whether any of the transformers in my uploaded workspaces (on FME Flow) are out of date or could be upgraded.
Right now, the only method I know is to download each workspace one by one, open it in FME Form, run the upgrade process, and then re-publish it back to Flow. That feels quite time-consuming when you have many workspaces.
Is there a built-in feature, script, or workaround that can help identify which workspaces contain upgradable transformers without having to go through them individually?
Thanks in advance for any tips!
Forum|alt.badge.img+54
  • Aug 27, 2025 10:15 AM UTC
The fmw reader will return all transformers and their current_transformer_version and the max_transformer_version for a workspace.
  • Aug 27, 2025 11:25 AM UTC
Before you do, you may want to consider implications due to possible changes in default behavior, see https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Working_With_Transformer_Versions.htm#ShouldYouUpgrade
Personally, I hardly ever bulk upgrade transformers, and if I do, I do a full test run to compare the results from before and after, so that I’m certain that the behavior hasn’t changed.
nielsgerrits
Forum|alt.badge.img+67
This. I would not advise upgrading transformers without heavy testing. Only specific transformers when you have a problem or know what is going on. And still then test the results.
carolina_w
  • Aug 28, 2025 3:58 PM UTC
Alright! I'm going to have to take a closer look at that. It's really the isolation of which workspaces that have these upgradable transformers that I'm really after. I realise an automatic upgrade might be a bit of a wishful thinking on ny part.
