Cannot log into FME Server 2018.0 Docker deployment
  • Apr 20, 2018 5:32 PM UTC
  • 51 views
We have been running FME Server 2017.1 on Docker for a while, its great! I am trying to build a new FME Server 2018.0 on Docker and everything builds and I can bring up the log in page but after entering my credentials the page just clears out my info and nothing happens, I can hit the healthcheck rest endpoint and it says everything is "OK" but if I try and hit an endpoint that requires credentials I get the error:
"message": "Authentication failed: org.postgresql.util.PSQLException: ERROR: column l.last_updated does not exist\\n Position: 16"
I see that I am getting an error from the FME DB container log saying:
ERROR: column "guiline" of relation "fme_parameter" does not exist at character 117
I am using the FME Server 2018.0 as is, the only change is the EXTERNALHOSTNAME variable.
Any help would be appreciated.
Best answer by rylanatsafe
On quick glance, the error "ERROR: column l.last_updated does not exist\\n Position: 16" could appear if you are reusing the same database schema from FME Server 2017.1 for FME Server 2018.
Although if you are going through a "reinstall / upgrade-in-place" process – for example, included the down -v command – and plan to restore using the Web Interface, then I'm not certain why you experience this error!
  • Apr 20, 2018 5:33 PM UTC
@GerhardAtSafe, Safe Chat suggested I tag you on this.
rylanatsafe
Forum|alt.badge.img+14
  • Apr 24, 2018 6:14 PM UTC
  • Apr 24, 2018 6:35 PM UTC
Thanks for the hint on the down -v command. I had previously removed all containers and images and ran prune for both but something must have lingered.
