Can FME Find List of used Feature Classes from ArcGIS Pro File?
  • Nov 4, 2020 9:39 PM UTC
  • 99 views
Hi all,
I am wondering can FME find a way to list all feature classes used in my ArcGIS Pro map file?
If not can it do it with ArcGIS Desktop files i.e. .mxd?
I am struggling to find a way to do this without possibly Python
debbiatsafe
Forum|alt.badge.img+24
Hi @cardiofaz​
ArcGIS Pro map files appear to be JSON-based (you can verify this by opening a .mapx file in a text editor). If this is the case, then you can try to use a JSON reader. Alternatively, you can also read the .mapx as a text file and use JSON transformers to extract the data you want. Here are some good resources for working with JSON in FME.
I hope this information helps!
  • Nov 5, 2020 10:15 PM UTC
Hi @cardiofaz​
Thank You much appreciated
