I recently installed 2016 64-bit FME. I had previously been running 2015 32-bit. I was a bit leery about going to 64-bit as I primarily write out to Esri formats, but after doing quite a bit of research I verified the readers/writers I use will work with 64-bit. That said, 2016 64-bit did work. I tested it on a workflow that pulls data from 16 feature types, writes out 6 feature classes into our SDE environment (72,163 total features), and contains 128 transformers. It took 10 min 19.5 sec, and the peak process memory usage was 1,319,888 kB. The problem is that I also ran it in FME 2015 32-bit and it took 8 min 37.3 sec and the peak process memory usage was 1,095,360. As another test, I installed FME 2016 32-bit. This process took 9 minutes 34.6 seconds and the peak process memory usage was 1,088,980 kB. Does anyone have any thoughts as to why the 64-bit version took quite a bit longer to run? Also, why might 2016 be slower than 2015? This really seems counter intuitive. Thank you for any suggestions you might have!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
