12 Days of FME Contest is Live: The Treasure Hunt Begins!
  • November 26, 2025
  • 78 replies
  • 2982 views
danielleatsafe
Forum|alt.badge.img+24
Ahoy, our annual 12 Days of FME Contest is live! This year we’re embarking on a Treasure Hunt Adventure...
About the Contest
The hunt begins! Discover the legend of Greenbeard, the pirate lizard whose long-lost treasure is waiting to be found. Follow clues, solve puzzles, and place your flags on the map for a chance to win - the closer your guess, the bigger the prize.
The contest runs November 26 to December 12, 2025.
How It Works
  1. Login to your FME Community account.
  2. Visit the Puzzle Board - your gateway to 20 puzzles.
  3. Each puzzle you solve reveals a clue to the treasure’s location.
  4. Head to the Make a Guess page to submit your guesses of the treasure’s location. You’ll start with 12 guesses and can earn bonus ones along the way.
  5. The closest guess to the treasure wins one of our grand prizes!
  6. Throughout the contest, connect with other users in the dedicated 12 Days of FME thread on the forums.
Tip: Participation is flexible - solve puzzles at your own pace anytime during the contest window. You must be logged into your community account to play.
Prizes
We have some incredible prizes up for grabs!
  • Closest Guess: The player whose flag lands closest to the treasure wins the first grand prize - a large Stump Craft (Canadian-made wooden puzzle) or Heye puzzle of your choice (up to $200 CAD value).
  • The next two closest players win the second and third grand prizes - a large Stump Craft or Heye Puzzle.
  • Special Achievement Prizes:
    • Worst guess: A fun FME swag pack including stickers, socks, and a spork!
    • Most puzzles solved: An FME hoodie to show off your puzzle-solving prowess
Plus four exclusive contest badges are available and automatically awarded depending on your level of participation.
Have questions or comments? Write them below. Hope you’ll join in on the fun!
Cheers,
The Safe Community Team
vancitygis
Participant
Forum|alt.badge.img+3
  • Participant
  • November 26, 2025
I’m having trouble opening the first FME puzzle dataset, it says it cannot recognize the file header.  I’m on FME 2023. Do we need any specific FME versions for this?
earlw
Forum|alt.badge.img+13
  • November 26, 2025
Anyone else having issues with puzzle 1. I have the code decoded but the key word is not being accepted?? Any special tricks?
evieatsafe
  • November 26, 2025
Hi ​@vancitygis yes, unfortunately the FFS files were made using FME 2024.0 so you would need to upgrade. I have converted that specific file to GeoJSON so you should be able to use this in any version of FME (attached) hopefully that helps!!
jedi121
Forum|alt.badge.img+5
  • November 27, 2025
Thank you but as the puzzle 1 of line 2 is also using a FFS file so it’ll be difficult. As I’l in a big company I don’t have the leisure to upgrade myself. This is the end of this Treasure Hunt for me :(
And as Safe has drastically changed it’s licence program for hobbyist since 2023 I can’t even use a FME at home for this. It’s a pity.
melissanilsson
Forum|alt.badge.img+15
When I place my guess it says Guess Submitted (coords) and Guess Count Updated but it doesn’t submit the guess and my count is still the same, when I check User Dashboard it says Guesses Made: 0 and it’s the same if i guess random.
kateaew
Forum|alt.badge.img+11
  • November 27, 2025
I am so stuck on the codes puzzle 3 finding the custom transformer name 😂 any hints/tips?
kateaew
  • November 27, 2025
I did mine in all lower case, unsure if it makes a difference!
mark2atsafe
Forum|alt.badge.img+59
  • November 27, 2025
@earlw No special tricks necessary and it’s not case sensitive.
I managed to find the log of your submissions on FME Flow and the simple solution is that your answer is incorrect!
Sorry about that! Pleae have another go at deciphering the text and try again!
mark2atsafe
  • November 27, 2025
My apologies for the FFS version problem. I guess I had a brain fade and didn’t consider how it would cause problems for users with older FME versions. I’ll put some updated versions (maybe older FFS, maybe a different format) as soon as I can.
mark2atsafe
  • November 27, 2025
Hi all (particularly ​@vancitygis and ​@jedi121 ) - I’ve updated the puzzles that use FFS data with alternative options to use a 2023.0.0.3 version of the data. I think that’s about as old as I can go.
fyi - the main version is FME 2025.0, not 2024 as mentioned earlier.
jeroen_hack
  • November 28, 2025
Hi, i found one of the codes for extra guesses. WHen i used it it mentioned the extra guess, but i don't see it updated on my Guesses page (still says 12). Did i do something wrong?
ivensl
Participant
Forum|alt.badge.img+4
  • Participant
  • November 28, 2025
Where did you paste the code to redeem it please?
dosh
Forum|alt.badge.img+7
  • November 28, 2025
On the main FME community home page scroll down until you see the “Redeem Reward Code” on the right hand side
jeroen_hack
  • November 28, 2025
Yeah like dosh said: On the main FME community home page scroll down until you see the “Redeem Reward Code” on the right hand side. After redeeming it said it was successful adding a guess and 5 points
kateaew
  • November 28, 2025
Unsure if my guesses are counting or not. Guess count never updates, even with the codes for extra guesses it doesn’t update :(
jonas_nelson
Forum|alt.badge.img+28
  • December 1, 2025
Same here - I’ve made 4 guesses so far (and they show on my map), but the statistics below the map still say that I’ve used 0 guesses and have 12 remaining (and the extra guess you got for redeeming the code after the webinar doesn’t seem to have registered either).
harrcapp
Forum|alt.badge.img+10
  • December 2, 2025
DateTimeIntervalCreator - FME Hub
harrcapp
  • December 2, 2025
For the instructions of Row 2 FME Puzzle 5, is this saying the centre of rotation is relative to the individual section or the overall image?
mark2atsafe
  • December 3, 2025
Hi ​@kateaew
I checked, and your guesses are being included. So far you have made 11 guesses and have 3 remaining.
Is the User Dashboard still giving an incorrect number of guesses?
If you paste this URL into a browser, does it return the correct number?
https://community-fme-server-support.fmecloud.com/fmedatastreaming/Treasure25/Dashboard-User-GuessesRemaining.fmw?userid=5037&token=72705d983f8fb2dc296674db2a78888ca2fa63df
Other users - you can test the URL by inserting your user ID instead of 5037 - it will be the last 4 or 5 digits on your profile page URL.
If it works, perhaps on the User Dashboard page you can open the developer tools and see if an error occurs? On Chrome I can press F12 to open that window.
In fact, the job logs on FME Flow report no errors, so I think it must be a web problem somewhere.
Apologies for the problems,
Mark
mark2atsafe
  • December 3, 2025
Hi ​@jonas_nelson
You seem to have the same problem as ​@kateaew - your guesses have been correctly submitted, but the display isn’t updating with the correct information. I have no idea why.
So far, you have made 4 guesses and have 9 remaining.
This is the URL to fetch your number of guesses remaining:
https://community-fme-server-support.fmecloud.com/fmedatastreaming/Treasure25/Dashboard-User-GuessesRemaining.fmw?userid=12004&token=72705d983f8fb2dc296674db2a78888ca2fa63df
Perhaps you, too, could visit the Dashboard page and check for errors in the developer dialog?
Regards
Mark
mark2atsafe
  • December 3, 2025
Hi ​@jeroen_hack
No, I don’t see anything wrong. You have made 0 guesses so far, and have 14 remaining (so the codes obviously worked). It must be a problem with the User Dashboard page.
You could try the direct URL (as I mentioned to ​@jonas_nelson and ​@kateaew in previous messages. But I just thought maybe it’s the map and the stats workspaces getting tangled up in each other. If you visit this page:
https://community.safe.com/p/12days25userstats?
Does that give you the correct statistics? Other people feel free to try this, too. It’s just the basic stats with no map. If that works I’ll permanently separate the two components into different pages.
Regards
Mark
mark2atsafe
  • December 3, 2025
I also updated the Guesses Remaining workspace.
If it couldn’t find a result, it used to show 12 as the default because it assumed you hadn’t signed up yet. Now it posts a text message for a couple of different scenarios.
It really shouldn’t be this, because I can see records for each of you in the “users” table, but we’ll see.
Mark
mark2atsafe
  • December 3, 2025
Aha! I think I spotted the problem. Can you try the page again, please? It should all work correctly now.
jonas_nelson
  • December 4, 2025
Thanks Mark, it works now and shows the correct number of guesses! :-)
jeroen_hack
  • December 4, 2025
@mark2atsafe Yes, it seems to work now. I see 14 guesses. Time to start redeeming those other codes I found!
