WorkspaceRunner and variable
  • November 5, 2024
  • 8 replies
  • 60 views
olivierl
Forum|alt.badge.img+3
Hello,
I would like to test a variable before running a workspaceRunner or not.
if attribute ‘recetteCouche’ = 1 then running workspaceRunner ‘000_recetteCouche..’0’ else if attribute ‘ecritureLivrable’ = 1 then running workspace ‘0000_ecritureLivra...’, etc
my configuration for each  WSR is : ‘wait job job to complete = YES’
Please, someone have an idea ?
Olivier.
Best answer by bwn
Lots of different ways.  Basic way of Prioritising and running a Workspace with a dynamic value for its Path below.
Sample Excel data.
Feeds into a Prioritisation using Eg. Sorter and Sampler.
tomfriedl
Forum|alt.badge.img+13
  • November 5, 2024
You can use a Tester or TestFilter before the WorkspaceRunner.
olivierl
  • November 5, 2024
Thanks but you can imagine i tried it before without successing
tomfriedl
  • November 5, 2024
Where are the attributes to filter? You use only the Creator before the WorkspaceRunner.
olivierl
  • November 5, 2024
This is an excel file with  an attribute for each workspace Runner set to true or false
bwn
Forum|alt.badge.img+26
  • November 6, 2024
Sample Excel data.
olivierl
  • November 6, 2024
Great ! works perfectly
Thanks a lot
olivierl
  • November 6, 2024
i completed with :
  • ‘tester’ for run = 1
  • set sampling Rate (N) to the max of ‘controle’
  • included user parameters in to workspace (even if few of the 10 .fmw don’t need all)
Meaby an other way to do it but this one works
Thanks again
olivierl
  • November 6, 2024
forgot this
