UUID generator in GDB in text format
  • Aug 1, 2017 12:20 PM UTC
  • 11 replies
  • 126 views
gis2020
Forum|alt.badge.img+5
Hi All,
I have a data in GDB with some field ID and i want to generate UUID for this in specific format.
for this i have used UUID generator but results are not as per my retirements.i.e 32 digit with dash in between eg.
I want Entity_ID in such format : 000000000-0000-0000-0000-000000000012.
last digit should be from Field ID field.
I am not sure which transformer i can use to do this can some body guide me on this ?
Forum|alt.badge.img+63
The UUIDGenerator should create a UUID in that format. Can you doublecheck this in the Data Inspector?
Are you writing to an existing database? If so, how is the field Entity_ID defined? How are you viewing the data?
gis2020
  • Aug 1, 2017 12:54 PM UTC
Hi @redgeographics it's creating entity_ID in this format like "1261736a-984c-4eb6-96c6-54cda1aaba76" but i dont want numbers in first 4 parts.entity-id.jpg. like for example field ID is 363496 so it should required UUID will be 000000000-0000-0000-0000-000000363496
danilo_fme
Forum|alt.badge.img+58
  • Aug 1, 2017 12:55 PM UTC
Hi @dandekarpriya, to get the last digit you can use the transformer StringSearcher:
Thanks,
Danilo
Aha, try this:
This will probably become a problem if your id's are more than 12 characters long because you'll have to deal with the last - as well. Also... if the last digits of the original uuid are similar to what might be contained in your id's, especially if the number of characters in the id is variable, you may end up with not-unique strings. There's probably enough random stuff happening in the first part of the uuid to prevent that, but I'd be wary to start tinkering with something that's supposed to be unique.
  • Aug 1, 2017 1:17 PM UTC
Have a look at the StringFormatter and the StringConcatenator.
gis2020
  • Aug 1, 2017 1:23 PM UTC
Aha, try this:
Hi @takashi is there a way i can just append my field_ID to other string with values zero value . so as to get the format 00000000-0000-0000-0000-000000000012
  • Aug 1, 2017 1:31 PM UTC
This screenshot illustrates my intention. Does this generate your desired formatted ID string?
trentatsafe
Forum|alt.badge.img+7
Hi @dandekarpriya
Just to confirm you want a UUID format but without the alphanumerical data? So for example, if you have the following:
UUID: 1261736a-984c-4eb6-96c6-54cda1aaba76
Field ID: 363496
You want your output to be '000000000-0000-0000-0000-000000363496' rather than '1261736a-984c-4eb6-96c6-54cda1363496'
Is that correct? If so, you will not want to use a UUID transformer, but I thinking something along the lines of what @takashi and @danilo_inovacao suggested.
gis2020
  • Aug 2, 2017 4:32 AM UTC
thank you @takashi it worked
  • Aug 2, 2017 5:00 AM UTC
Good to hear, but I may have to add a comment. That is, with the workflow above, the number of digits of the last part in the resulting ID string would be greater than 12 if the original field ID consists of 13 or more digits.
For example, if the field ID was this 18 digits string,
123456789012345678
the result would be
00000000-0000-0000-0000-123456789012345678
If you need to create
00000000-0000-0012-3456-789012345678
in this case, it would be necessary to modify the workflow.
tva
Forum|alt.badge.img+13
  • Feb 20, 2018 1:12 PM UTC
A bit late of a reply but use a StringReplacer:
Text to replace: (\\w{8})(\\w{4})(\\w{4})(\\w{4})(\\w{12})
Replacement Text:\\1-\\2-\\3-\\4-\\5
Which should solve the issue if your original string is longer than 12
