UTM to Ground
dmerrick
I have been trying to figure out how to correct reproject from UTM to Ground. I have many datasets in an SDE environment (WKID: 26910) that I want to convert to Autocad DWG format so the engineers can use the data without shifting to local reference points.
Dataset Coordinate System:
NAD_1983_UTM_Zone_10N WKID: 26910 Authority: EPSG
Projection: Transverse_Mercator False_Easting: 500000.0 False_Northing: 0.0 Central_Meridian: -123.0 Scale_Factor: 0.9996 Latitude_Of_Origin: 0.0 Linear Unit: Meter (1.0)
We have a trimble unit that GPS's in Ground with the following Projection settings:
Zone Parameters:
Zone Record: 10 North
Zone Type: Transverse Mercator
Origin Lat: 0 00'00.000" N
Origin Lng: 123 00'00.00 W
Origin North: 0.00
Origin East: 500,000.000
Origin Scale 0.9996000
Project Azimuth: North Azimuth
Coordinate Direction: North East
Datum Parameters:
Datum Name: Nad 1983 (Canada)
Translation X: 0.000m
Translation Y: 0.000m
Translation Z: 0.000m
Ellipse Parameters:
Ellipse Name: Geodetic Ref System 1980
Ellipse a: 6,378,137.000m
Ellipse 1/f: 298.257221538
I have been using the SAFE
https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw?
To try to create the correct coordinate system for my conversion but the best I can get is 250m away from where it should be.
Any help would be appreciated?
Thanks!
Best answer by dmerrick
@deanhowell after going back over the data with the engineers, what they wanted (coordinate system in ground), all I had to use was the Scaler transformer (Scale Origin at 0,0) to convert the data.
daveatsafe
Forum|alt.badge.img+19
  • July 20, 2018
Hi @dmerrick,
FME can automatically generate a local Azimuthal Equal Area coordinate system from your data and write that to the DWG file along with the data, using the CommonLocalReprojector transformer.
If you want more control over the location of the origin, you can also define a local Azimuthal Equal Area coordinate system through the web page, and reproject from UTM into that coordinate system before writing to DWG.
Both of these methods are fairly simple in FME, and would give you a more reliable result than trying to scale the UTM data, since the applicable scale factor changes with the distance from the central meridian.
deanhowell
Forum|alt.badge.img+23
  • December 18, 2019
Hello @dmerrick, I am trying to do the same thing (UTM Zone 53 to Ground) and was just wondering if you solved the problem.
deanhowell
  • December 18, 2019
daveatsafe wrote:
Hi @dmerrick,
Hello @daveatsafe do you have any examples or advice on this as I am trying to do a similar thing to @dmerrick. We want to be able to create an AutoCAD DWG that is in ground coordinates so the drafting team does not have to apply any transformation. The data is in grid coordinates using GDA2020 Zone 53 and we want to apply the transformation in FME to output the drawing in ground coordinates.
daveatsafe
  • December 18, 2019
Hi @deanhowell,
Please try sending the data through the CommonLocalReprojector before writing it to AutoCAD.
dmerrick
  • December 18, 2019
Hi @deanhowell, I had forgotten about this project (the Engineers shift/factor the data on their end), I will have another look at it.
deanhowell
  • December 18, 2019
daveatsafe wrote:
Hi @deanhowell,
Thanks @daveatsafe I will give that a go :)
dmerrick
  • December 20, 2019
dmerrick
  • December 20, 2019
deanhowell
  • December 21, 2019
Thanks that is what i did as well but the change to ground was so small that it didn't seem necessary but does seem effective once the scale factor was worked out. Thanks again
