Using Previously-Downloaded .xsd Files In Offline Processing?
  • Mar 21, 2018 10:18 AM UTC
  • 0 replies
  • 30 views
We are trying to build a workbench which can work offline if it needs to, but can't find a way to supply it with the .xsd schema files at run-time.
We already have the .xsd files (the data is from the Ordnance Survey, and they gave us the files) but haven't been able to find a good way to provide them to the workbench - It looks like the only way is to open the workbench file in a text editor and edit the XSD_DOC and SKIP_SCHEMA_LOCATION_IN_DATASET values.
Is there a way to tell the workbench to (optionally) look in a specified location for the schema?
