Unexpected result from Area on Area Overlayer
  • Dec 10, 2024 3:59 PM UTC
  • 134 views
rob_m_esriuk
We have two different buffer results from the same road network and I’m doing some work on identifying what is different
These are large multipart polygons and I wanted to chop them up to give common parts (overlay > 1) and individual parts. In the picture I want to separate the red hatched bit and the solid blue bits from  the combined data. Running the area on area overlayer with no grouping but creating a list of parts results in…
Where the orange hatching has created a fill in on the closed triangle  and the roundabout. This is not what I was expecting but I cannot find a setting on the transformer to avoid this.
Help!!!!
Thanks
Rob
mholemans
Forum|alt.badge.img+14
  • Dec 10, 2024 4:30 PM UTC
For the moment I don’t know the root cause for this behavior. A possible solution/workaround can be to use the Intersector instead of the areaOnAreaOverlayer?
Do you get the same results?
liamfez
Forum|alt.badge.img+44
  • Dec 10, 2024 4:54 PM UTC
Could also try the Clipper
