Triangulator and aggregate geometries
  • March 27, 2019
  • 7 views
Forum|alt.badge.img+33
The triangulator appears to no longer accept aggregate geometries, the option is to deaggregate or reject.
This means the approach mentioned here no longer works (unless you copy the triangulator from this workspace :-) )
https://knowledge.safe.com/articles/1310/how-to-clip-tin-surfaces.html
Is this expected? Should i be using a different approach??
  • March 28, 2019
Maybe this is why the triangulator didn't make @sigtill 's top list of transformers for working with 3d :-)
