Transforming a raster with a proj4 string that isn't in fme
  • Oct 20, 2020 1:10 PM UTC
  • 69 views
I want to transform a raster with radar rain data. It is open data from the Dutch meteorological society, originally in a h5 format. Tackled all that I still have problems getting the projection right. I would like get it to wgs84/EPSG4326 or another one more commonly used. The projection is described as follows +proj=stere +x_0=0 +y_0=0 +lat_0=90 +lon_0=0 +lat_ts=60 +a=6378.388 +b=6356.906. FME doesn't recognise the string and I have tried to donwload additional ones from the website. Does anyone know how to solve this?
The corner points are given in the picture.
Thanks in advance!transformation​
jkr_wrk
Forum|alt.badge.img+37
  • Oct 20, 2020 2:05 PM UTC
I tested the Proj string in QGis. It validates as a projection but is unable to convert between this projection and WGS or RDNAP. If you know your data, maybe QGis is the easiest way to reproject the data correct?
Edit: Additional info: http://osgeo-org.1560.x6.nabble.com/Dutch-3-uur-neerslagaccumulaties-van-het-KNMI-td5299683.html
