Sum values
  • January 17, 2020
  • 5 replies
  • 1078 views
nath
I think I have the easiest question ever but I've wasted too much time on it and it just won't work.
I just want to create a new attribute for each record with the result of the sum of 3 other values. The result of nieuw + renovatie + stroomopwaarts. It looks very easy but i have already tried everything and nothing works.
What am I missing?
Best answer by sigtill
Attributecreator and use the ARITHMETIC EDITOR and add the expression.
  • January 17, 2020
When creating the new attribute, make sure to use the arithmetic editor:
Then double-click on each attribute to insert it into the formula:
sigtill
Forum|alt.badge.img+24
  • January 17, 2020
nath
  • January 17, 2020
Omg that is so stupid. I did the same but forgot to use the arithmetic Editor
Thank you!
sigtill
  • January 17, 2020
Thank you!
Its an easy mistake, and something we have all done, and still do :)
Forum|alt.badge.img+31
  • January 17, 2020
Thank you!
If ever you needed a paperclip to pop up and say 'it looks like you're writing a formula, do you want to use the arithmetic editor?' this is it!
I thought I'd suggested an idea about warning if using math operators in the text editors but I can't find it right now.
