Split and convert shapefile into several kml files
  • October 11, 2017
  • 115 views
I am actually trying to split a big shapefile into several kml files according to an attribute variable. I would like one kml file per value of that variable, which makes about 600 kml files. Is it possible to do that with FME?
trentatsafe
Forum|alt.badge.img+7
Hello @aguy,
What you would be looking for is a Dataset fan. After your writer has been added to the workspace, if you go to the writer's properties in the Navigator and you will see a Fanout Dataset parameter. You would want to toggle this on, and change the Fanout Expression to what you want written(in your case likely @Value(attributeyouwant).kml
This will output a KML file per different attribute.
For more information: https://knowledge.safe.com/articles/565/fanout-1.html
dustin
Forum|alt.badge.img+36
  • October 11, 2017
You can use the fanout option to split the KML output data based on your variable attribute.
  • October 11, 2017
Thank you both, that worked!
