Running an FME Server job as a specific user
  • Aug 26, 2013 4:05 PM UTC
  • 5 replies
  • 265 views
nic_ran
Forum|alt.badge.img+20
I need to force an FME Server job to run under a specific Windows user account.
I have Active Directory authentication turned on for FME Server and I have granted permission to the user account (via a role) to the job that I need to run.
I need a way of forcing the job to run under a specific account, no matter who is logged in and running the actual job. The reason I need to force to run under a specific account is that the job needs access to data in a network drive location that only that user account can see.
I know that I can set FME Server up to use a default account at the Service level (e.g. Job Submitter, Data Download, etc.) but I need to be able to do this for just a specific job.
Is this possible?
Nic
nic_ran
  • Aug 26, 2013 5:03 PM UTC
Bonus points for telling me how this might be possible for a scheduled job....
  • Aug 27, 2013 2:46 PM UTC
Hi Nic,
You can use the sysinternal utility "ShellRunas" for starting anything in windows with a different user account.
Marc
nic_ran
  • Aug 27, 2013 4:39 PM UTC
Thanks. I was hoping to run the job on FME Server but maybe I can take a modified version of your suggestion and have a batch script call Runas to run an FME Desktop instance. Not ideal but it should work.
Nic
helmoet
Forum|alt.badge.img+8
  • Jul 4, 2017 12:18 PM UTC
Hi @nic_ran, you can create a separate workspace using a workspacerunner to schedule your job. Publish the user authentication parameters for the workspacerunning and publish it to FME Server.
helmoet
  • Jul 4, 2017 12:20 PM UTC
Sorry, FMEServerJobSubmitter. Also works for schedules.
