Reverse search using string function FindString() (negative startIndex?)
  • Jul 17, 2023 6:01 AM UTC
  • 451 views
thijsknapen
Forum|alt.badge.img+12
Say I have data like the following;
sequence_path (string: UTF-8): 1.2.3.4
As a result I wanted to fetch the parent from this sequence_path (i.e. '1.2.3').
In order to do so I wanted to do the following;
  • Use a reverse search to find the position of the last '.' in the string,
  • Fetch the (Left) substring up to the position of this last '.'
To perform the first step, I thought to use the FindString() string function (with a negative startIndex).
So, at first I thought that @FindString(@Value(sequence_path),.,-1) could be used. However, that returned '-1' (not found). However, somewhat unexpectedly at first, I noticed that '@FindString(@Value(sequence_path),.,-2) ' did return the desired value.
Upon second reading of the String Functions documentation: "If startIdx is a negative integer, FindString() returns the index in str starting at startIdx from the end of string , then matching strToFind going forward (from left to right)."
I now notice that the search is still from left to right (forward), however only from the negative index onward.
E.g. '@FindString(@Value(sequence_path),.,-3)', seems to look for a dot in '3.4', to find it in the second spot (index '1'), and then return 5 as the result (5 = 7-3+1 = StringLength + startIndex + matchIndex).
Is it possible to perform a reverse search (search from right to left) in a (non-Regex) StringSearcher function/transformer?
ps. from an efficiency perspective, I would like to avoid StringSearches that rely on Regular Expressions.
geomancer
Forum|alt.badge.img+71
  • Jul 17, 2023 12:33 PM UTC
You can always reverse the string or use the StringReverser (FME Hub)😁
thijsknapen
  • Jul 19, 2023 7:46 AM UTC
Tnx for the idea geomancer. For my current usecase I decided to use @TrimRight(@TrimRight(@Value(sequence_path),0123456789),.)
My question was inspired by the observation that the Oracle SQL instr function has the option to perform a reverse search, but SQLite SQL instr function does not. To work around this in SQLite SQL I already found this workaround; https://stackoverflow.com/questions/21388820/how-to-get-the-last-index-of-a-substring-in-sqlite).
I was just wondering if FME StringSearcher functions would support reverse searching, but I guess not.
My question was mainly from an efficiency perspective (nr of features could get up to millions), and I have some worries that introducing an additional step of reversing the string won't be more efficient than actually using Regular Expression searches.
