Reprojecting raster tiles, output doubles in size
bjudes
Forum|alt.badge.img+10
I have a set of 250 raster tiles, I have reprojected them from ITM to WGS84, before reprojection each tile was 87,215KB. After reprojection the tiles are roughly 180,000KB. Why has this happened? My workbench is included here, I first mosaicked the tiles then reprojected and finally clipped back to the tile boundaries.
Thanks for any help.
B
Best answer by takashi
A possible reason is that the source raster data is compressed whereas the destination raster data is not compressed.
Check if the source raster data is compressed with some method. You can see the compression method in the Feature Information window of FME Data Inspector, if it was compressed.
e.g.
  • March 13, 2019
e.g.
bjudes
  • March 13, 2019
e.g.
Hi Takashi,
Thanks for the help, the original does not appear to be compressed. See below. Would there be a stretch applied going to wgs84 that would cause the data to increase in size?
Thanks
B
  • March 13, 2019
e.g.
hmm, I cannot find any other reason.
Could you please post a screenshot of Feature Information about the resulting raster too? There could be a hint.
bjudes
  • March 13, 2019
Should have done that the first time. Thanks for the help.
  • March 13, 2019
The raster interpretation has changed. Original was UINT8 but the result is UINT16. I think it's the direct reason why the file size increased approximately double.
  • March 13, 2019
Try inserting the RasterPaletteResolver before the RasterMosaicker, and the RasterPaletteGenerator (Palette Key Interpretation Type: UInt8) before the destination writer feature type.
bjudes
  • March 13, 2019
Great stuff, thanks for the help. I will post the results when I get them.
bjudes
  • March 13, 2019
Hi Takashi, I've started the process again and the output is much closer to the original size. Thanks for the great help.
bjudes
  • March 19, 2019
@takashi, sorry to open this up again, I have encountered a problem with the output file. The reprojection has caused the tiles to have black edges.
I initially mosaicked the raster tiles together to try and avoid this and it worked with the larger output tiles, but since including the RasterPaletteResolver and the RasterPaletteGenerator I now have black edges and tiles that don't fit together. Please see image below.
Thanks
B
  • March 19, 2019
Thanks
B
If you can treat every pure black (0, 0, 0) cell as Nodata, set 0 to the Nodata with the RasterBandNodataSetter before the RasterMosaicker.
bjudes
  • March 19, 2019
Thanks for the help. I tried this and the output came out the same. Seems strange.
  • March 19, 2019
Thanks
B
Well, how about setting Maximum to the Overlapping Values parameter in the RasterMosaicker?
bjudes
  • March 19, 2019
I am running this now, out of interest would you know why adding the two RasterPalette transformers has brought back the black outline?
Thanks for your help. I appreciate it.
  • March 19, 2019
Thanks
B
I guess that the black edges have been brought by reprojection, rather than the palette operations.
bjudes
  • March 19, 2019
But when I undertook this same process initially, there were no black edges (just the file sizes doubling). It was since the introduction of the palette operations the black edges appeared.
  • March 19, 2019
Thanks
B
Possibly reprojection caused Nodata outlines but the original palette definition didn't have the entry for representing the Nodata color.
What happens if you apply the RasterPaletteResolver before reprojection?
bjudes
  • March 19, 2019
I've had the Palette Resolver before reprojection the whole time. I have attached a copy of the workbench below. Thanks
DISCOVERY_REPROJECT_NEW_WORKSTATION.fmw
bjudes
  • March 19, 2019
The Palette resolver has been before the reprojection throughout all the tests. I have attached a copy of the workspace below.
Setting the Overlapping Values to Maximum has not worked either.
  • March 19, 2019
Could you please share two tiff files adjoining each other, which reproduce the situation?
bjudes
  • March 19, 2019
I've uploaded the tiffs to google driver, link below. Thanks B
https://drive.google.com/drive/folders/18YosUVEowILL2tFkmC4k7tCLfq7yN0-s?usp=sharing
bjudes
  • March 19, 2019
I have setup the workbench with the RasterBandNoDataSetter just before the writer and it has removed the black data. I've only done it on the sample of the two tiles I sent to you above. I'm going to run a larger area, hopefully the results will be the same. Thanks so much for your help so far. B
  • March 19, 2019
Try inserting a RasterBandNodataSetter (Nodata value: 0) between the RasterPaletteResolver and the RaterMosaicker.
bjudes
  • March 20, 2019
I seem to get the best output when I put the rasterbandnodatasetter before the writer. You have been a great help. Thanks B
bjudes
  • March 25, 2019
@takashi Sorry I have another question. When I view the output tiles they look great in inspector/arcmap etc, but looking at them in windows explorer I still have the black tile edges (see below). How come this is occurring, is there a way to remove the black? Thank you very much for the help thus far.
  • March 25, 2019
It seems that Windows Explorer ignores Nodata definition. It's just a preview anyway, I don't think it would cause any practical issues on using the data.
