Reading DWG block attributes, how to access?
  • Oct 4, 2018 12:17 PM UTC
  • 179 views
havmoejbv
Forum|alt.badge.img+16
I have some DWG files with data drawn as blocks with attributes. When I look at these in Data Inspector, I notice that the block attributes shows up in two ways:
I've read through https://knowledge.safe.com/articles/59335/autocad-dwg-block-attribute-extraction.html and see that while I can access the attribute info from the attribute lists (top marking) it would be a lot easier to just grab the info as shown at the bottom. The problem is I can't find this via e.g. the attribute exposer. Anyone got a good idea?
(Demo DWG attached)
Best answer by itay
Hi @havmoejbv,
I have just used your DWG and managed to successfully write the TEKST attribute value into a CSV.
I used an AttributeExposer and a CSV writer with the TEKST attribute added to it.
Hope this helps,
Itay
itay
Forum|alt.badge.img+19
  • Oct 4, 2018 1:04 PM UTC
Hi @havmoejbv,
Hope this helps,
Itay
havmoejbv
  • Oct 4, 2018 2:18 PM UTC
Hi @havmoejbv,
Hope this helps,
Itay
Oh, that's interresting. Even though the TEKST attribute doesn't show in the list of attributes in AttributeExposer, it can be added, and seems to be working as normal after that. I didn't even think of trying that. Thanks!
gio
Forum|alt.badge.img+15
  • Oct 4, 2018 2:27 PM UTC
@havmoejbv
the attribute_info{} is a list. (which you can explode or list index etc.)
In the list the object is known as a ..info{}.name and its value as ..info{}.value
The object is a AutoCAD text object, which explains the TEKST being available as an attribute.
