Raster cell replacer
  • May 22, 2017
  • 8 replies
  • 105 views
I hope someone can assist me. I need to round up all the cell values for a ascii grid file. This can be done in the spatial analyst esri tool reclassify.
ie. cellvalue = 10.00001 to 10.99999 round up to 11.
Is this easily possible for all values to round up ie 1,2,3 etc.
Thanks
  • May 23, 2017
Have a look at the RasterCellValueRounder. If you need integer values, leave the number of decimals at zero.
  • May 23, 2017
Maybe it works with the transformer "RasterInterpretationCoercer", the values are rounded because you've only 256 values. For my work I've selected the option "UInt8".
  • May 23, 2017
Hi David,
Would it be possible to round up a whole number ie 10.00000 to 10.99999 = 11? using the RasterCellValueRounder?
thanks
lau
Forum|alt.badge.img+3
  • May 23, 2017
Have you tried the RasterCellValueReplacer?
Another solution is to define ranges in the RasterExpressionEvaluator.
--> https://knowledge.safe.com/articles/1226/using-conditions-with-the-rasterexpressionevaluato.html
  • May 23, 2017
I tried the RasterCellValueReplacer however due to the change to full numbers ie 10.0000 0 to 10.99999 = 11 when the next RasterCellValueReplacer runs ie 11.0000 0 to 11.99999 to 12 it obviously replaces the 11 is previously created with 12. Esri's reclassify does not have this issue as i cannot find a way to do the entire file withour pushing it through multiple replace transformer.
The ExpressionEvaluator could work but im not sure how i capture these full numbers.
lau
  • May 23, 2017
If you use multiple RasterCellValueReplacer and starts to define the highest ranges, you would not encounter this kind of issue
  • May 25, 2017
Hi David,
thanks
If you set the rounding direction to "up" you will get
11.0 -> 11
11.1 -> 12
11.9 -> 12
12.0 -> 12
12.1 -> 13
etc
gio
Forum|alt.badge.img+15
  • May 26, 2017
RasterInterpretationCoercer can be used to cast the values.
Convert float to integer can be set to ceiling.
