Python based transformer with multiple INPUT tags fails
  • October 8, 2016
  • 5 replies
  • 111 views
I'm reopening the issue in the below post, as it seems that there may be a bug involved:
It seems that when I use an input tag like this: INPUT_TAGS: INPUT1 INPUT2
and a template with: $(INPUT_LINES) for both (it works, generating two factory input tags),
FME translates this into a Python factory definition with these input tags:
INPUT INPUT1 FEATURE_TYPE AttributeCreator_OUTPUT
INPUT INPUT2 FEATURE_TYPE AttributeCreator_2_OUTPUT
The problem as I see it, is that this syntax is illegal, hence a bug.
The factory documentation states that it must look like:
Syntax
FACTORY_DEF <ReaderKeyword> PythonFactory
[FACTORY_NAME <factory name>]
[INPUT FEATURE_TYPE <feature type>
[<attribute name> <attribute value>]*
[<feature function>]*]*
SYMBOL_NAME <python symbol name>
[SOURCE_CODE <source code>]
[PYTHON_NAMESPACE FMEOBJECTS]
[OUTPUT PYOUTPUT FEATURE_TYPE <feature type>
I.e.. nothing between "INPUT" and "FEATURE_TYPE", which explains the error messages I'm getting:
The input tag 'INPUT1' in 'FACTORY_DEF .....' is not a valid input tag for this factory
Is the documentation in error, or is there a bug in the automatic translation. Please advise.
Thanks.
Lars I.
  • October 8, 2016
Here's the full FMX file.crossjoiner.fmx
  • October 8, 2016
  • October 8, 2016
Hi again,
Just to test my bug hypothesis, I replaced the $(INPUT_LINES) with an edited version of the input tags in the auto-translated factory definition:
INPUT FEATURE_TYPE AttributeCreator_OUTPUT
INPUT FEATURE_TYPE AttributeCreator_2_OUTPUT
And now it works, and my transformer receives the two input features, and outputs them again (unaltered sofar).
But I have my transformer logging the feature type of the input features (i.e. FMEFeature attribute "fme_feature_type"), but they report "Creator" and "Creator_2", which are how the features are initially created in my test workspace.
How does this mismatch (e.g. between feature type "Creator" and tag "AttributeCreator_OUTPUT") work ??
Thanks
Lars I.
  • October 8, 2016
Hi again,
Thanks
Lars I.
Here's a screenshot of my test workspace:
  • October 8, 2016
Hi again,
Thanks
Lars I.
Ah, the FMEFeature method "getFeatureType()" returns another value, and this corresponds with the factory feature type tag names. That puzzle's solved then :-)
