Processing Survey Responses from a Survey Monkey Survey
  • Dec 6, 2017 5:32 PM UTC
  • 62 views
Hello: Has anyone attempted to use FME to capture survey responses from Survey Monkey? If so, what approach did you take? I don't have python experience but I have a survey I need to automate processing the survey responses. Any help or advice is welcomed.
@bcrowley10 , it looks like Survey Monkey has an open API so you should be able use a HTTPCaller transformer to make calls to it - check out the API document and register for an API key. In fact I need to do this myself later this week so will try it out then
  • Dec 6, 2017 5:50 PM UTC
OK. I'll start there and give it a try. Thank you!
