Problems with google geocoder
  • Apr 12, 2018 6:31 PM UTC
  • 78 views
I have one workspace that uses GoogleGeocoder, but in some weeks ago, my workspace don´t work properly. Below follow the log:
2018-03-23 13:43:38| 4.2| 4.2|STATS |Router and Unexpected Input Remover(RoutingFactory): Tested 5 input feature(s), wrote 5 output feature(s): 5 matched merge filters, 5 were routed to output, 0 could not be routed.
2018-03-23 13:43:38| 4.2| 0.0|STATS |Unexpected Input Remover Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:38| 4.2| 0.0|STATS |Plan1 (XLSXR_1) Splitter(TeeFactory): Cloned 5 input feature(s) into 5 output feature(s)
2018-03-23 13:43:38| 4.2| 0.0|STATS |Plan1_XLSXR_1 Feature Counter -1 18(TeeFactory): Cloned 5 input feature(s) into 5 output feature(s)
2018-03-23 13:43:38| 4.2| 0.0|STATS |Geocoder_CATCHER(TeeFactory): Cloned 5 input feature(s) into 5 output feature(s)
2018-03-23 13:43:39| 5.4| 1.2|WARN |Geocoder (Geocoder): Geocoding result invalid, status: 'ERROR - Unhandled Exception'. If using attribute values for geocoding parameters, please check your data for errors
2018-03-23 13:43:40| 5.8| 0.3|WARN |... Last line repeated 4 times ...
2018-03-23 13:43:40| 5.8| 0.0|STATS |Geocoder_ROUTER(TestFactory): Tested 5 input feature(s) -- 0 feature(s) passed and 5 feature(s) failed
2018-03-23 13:43:40| 5.8| 0.0|STATS |Geocoder_OUTPUT Feature Counter -1 25(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Geocoder_<REJECTED> Feature Counter -1 2147680280(TeeFactory): Cloned 5 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |AttributeCreator_10_OUTPUT Feature Counter -1 21(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |StatisticsCalculator_InputProcessor(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |StatisticsCalculator_UnneededInputNuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |StatisticsCalculator_CompleteOutputter(SortFactory): Output 0 feature(s) without doing any sorting
2018-03-23 13:43:40| 5.8| 0.0|STATS |StatisticsCalculator_SummaryCreator(CreationFactory): Created 0 features
2018-03-23 13:43:40| 5.8| 0.0|STATS |StatisticsCalculator_SummaryExploder(ElementFactory): Split out 0 list elements from 0 input features, using mode LEAN_AND_MEAN
2018-03-23 13:43:40| 5.8| 0.0|STATS |StatisticsCalculator_COMPLETE Feature Counter -1 100(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Cloner_CheckCopies(TestFactory): Tested 0 input feature(s) -- 0 feature(s) passed and 0 feature(s) failed
2018-03-23 13:43:40| 5.8| 0.0|STATS |Cloner_Cloner(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Cloner COPY Splitter(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Cloner_COPY_0_Zf4bepd9Vqs= Feature Counter -1 173(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Cloner_COPY_1_MykS6/DIvjg= Feature Counter -1 182(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Cloner_COPY_1_MykS6/DIvjg= Disabled Nuker -1 182(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Cloner_<REJECTED> Feature Counter -1 2147680293(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Destination Feature Type Routing Correlator(RoutingFactory): Tested 0 input feature(s), wrote 0 output feature(s): 0 matched merge filters, 0 were routed to output, 0 could not be routed.
2018-03-23 13:43:40| 5.8| 0.0|STATS |Final Output Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2018-03-23 13:43:40| 5.8| 0.0|STATS |Stored 5 feature(s) to FME feature store file `E:\\TEMP\\no-conn-ffs-152182341363_3604.ffs'
2018-03-23 13:43:40| 5.8| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2018-03-23 13:43:40| 5.8| 0.0|STATS | Features Written
2018-03-23 13:43:40| 5.8| 0.0|STATS |Geocoder_<REJECTED> 5
2018-03-23 13:43:40| 5.8| 0.0|STATS |==============================================================================
2018-03-23 13:43:40| 5.8| 0.0|STATS |Total Features Written 5
2018-03-23 13:43:40| 5.8| 0.0|STATS | Features Read Summary
2018-03-23 13:43:40| 5.8| 0.0|STATS |Plan1 5
2018-03-23 13:43:40| 5.8| 0.0|STATS |Total Features Read 5
2018-03-23 13:43:40| 5.8| 0.0|STATS | Features Written Summary
2018-03-23 13:43:40| 5.8| 0.0|STATS |Total Features Written 0
Translation was SUCCESSFUL
My data is going out by REJECT output in GoogleGeocoder Transformer.
Thank´s
Forum|alt.badge.img+63
The error message says: "Geocoder (Geocoder): Geocoding result invalid, status: 'ERROR - Unhandled Exception'. If using attribute values for geocoding parameters, please check your data for errors"
Could you doublecheck the addresses you're trying to geocode? Since it reports that error for all features it's probably not a malformed address or something but without seeing the data it's hard to tell.
Hi @redgeographics,
I guess that same information. But if I leave the same data for the other location and works in the other machine, the transformer work properly.
Thanks
