Preserving ESRI Domain Descriptions (not codes) when exporting data.
  • September 20, 2023
  • 6 replies
  • 419 views
000craig
Pretty simple data export, I have a reader referencing some SDE data and then a writer to a file geodatabase. But reviewing the attributes in the file geodatabase I see that the domain attributes are the codes (1,2.3, etc) not the descriptions (copper, steel, PVC, etc).
Is there a way to write the domain descriptions and not codes?
The same is true for the subtypes, it is writing the code (1,2,3) and not the description (tap, bend, saddle, etc).
Best answer by sammy
000craig wrote:
In the Reader > Properties > Constraints > Resolve Domains.
Looks like this preserves the domain descriptions but unfortunately does it by creating duplicate fields with appended names, which in our case is a show stopper.
Also noticed that for some reason it was not applied to all fields with domains.
Also noticed that 'Resolve Subtype' dosn't appear to work.
Just some notes in case anyone else comes across this. If you aren't restricted by strict naming conventions you can get the data out with domain descriptions.
@000craig​ I am dealing with the duplicate fields you mentioned in 2 steps:
  1. AttributeRemover: select the original fields with the coded values to remove them.
  2. BulkAttributeRenamer: apply to all fields and replace string “_resolved” with nothing. Now you will have the original field names but for the description value columns instead of coded values.
There may be a more efficient way to do that but this works for what I need.
000craig
sammy
Forum|alt.badge.img+17
  • January 19, 2024
Can I ask what specific reader you are using and what version of FME you are using?
I am also having an issue where some of my fields are not being resolved.
I am using FME Workbench 2023.1 and using an ESRI ArcGIS Portal Feature Service Reader to read in Utility Network Data.
I have 3 attributes that are not successfully resolving:
  1. Asset Group (this is a subtype and based on this thread, it's a known issue: https://community.safe.com/s/question/0D54Q00009hR8pFSAS/esri-utility-network-reader-subtype-layer )
  2. I have a text, coded domain attribute that is not resolving (even though other similar attributes are)
  3. I have a numerical (short), range domain attribute that is not resolving
So I am curious about the details of your resolving domain issues as I am trying to troubleshoot my issues.
sammy
  • January 19, 2024
Screenshot 2024-01-19 110306Oh, actually, I just saw the comment on that thread I mentioned above that said to expose the format attribute "arcgisonline_subtype_name" in the reader if you want the Asset Group subtype description to be added as a field. I did that and it worked for me.
Now I just need to figure out how to get the other two fields working.
sammy
  • January 19, 2024
Following up about my issue with the text, coded domain that was not showing any description values in fme (issue #2 on my list above). The problem is actually with the domain definition in the feature service not with the fme reader. So I have to fix my feature service to resolve this issue.
Also, for the range domain field (issue #3 on my list above), I think that it is correct that there won’t be any values for fme to resolve as there aren’t any code-description definitions for this type of domain. So this is also not an issue with the fme reader not working correctly.
sammy
  • January 19, 2024
000craig
  • January 23, 2024
Hi, thank you for providing more information on this process. Sorry I wasn't able to provide any help, FME is new into our operations so were still in a learning phase. I will definitely review our process and see if we can revive with your input, thanks!
