Passing a list parameter to an FME workbench from the command line
  • Aug 31, 2021 8:02 AM UTC
  • 442 views
sparki
Participant
Forum|alt.badge.img+4
Hello,
I am passing in a list of values to a user parameter (eg: LGA LGATYPE ABBNAME). The user parameter is assigned to a parameter of ChangeDetector (Selected Attributes).
2021-08-31 17_58_42-ChangeDetector Parameters
If I open the FME workbench and run it, the ChangeDetector recognises the parameter value passed as a list of attributes. It then uses those attributes to check for any differences between 2 datasets. That is as expected.
However, if I run the tool from the command line and pass in the attribute list as a parameter, (eg: LGA LGATYPE ABBNAME), ChangeDetector does not recognise it as a list and does not find any attribute based changes.
If I reduce the command line parameter down to just one attribute (eg: LGA) then it works.
The parameter is a list parameter:
2021-08-31 18_09_21-User Parameters for 'Main'
Any thoughts on what might be going wrong?
  • Aug 31, 2021 8:10 AM UTC
Make sure you have double quotation marks around the list of values, e.g.
--MATCHATTRS "LGA LGATYPE ABBNAME"
sparki
Participant
  • Participant
  • Aug 31, 2021 11:15 PM UTC
Thanks for the reply David.
Sorry, I should not have said 'command line'. I am calling this from a Python program and I am using ArcGIS Data Interoperability extension to access FME functionality.
The parameter is passed as a string. I am logging the parameter values using MessageLogger and if I use additional quotes then I can see those quotes as part of the parameter value, ie `_MATCHATTRS' has value `"LGA LGATYPE ABBNAME"' and it doesn't fix the ChangeDetector issue.
Looking at the parameter logs for both the FME workbench run and the Python run I cannot see any difference if values, which has me confused: `_MATCHATTRS' has value `LGA LGATYPE ABBNAME'. It kind of makes me feel like FME is not interpreting the parameter as a list but rather a single value, when passed through Python.
