Need dynamic loopup table for schema mapper??
  • Dec 27, 2017 10:31 PM UTC
  • 6 replies
  • 106 views
I would like to create a csv file and set that to Schema mapper.. cause I have a requirement which will generate data dynamically from the folder which contains multiple zip files..
Looping through Folder --> FeatureReader(Merging all shape files)-- > Generic --> Schema Mapper (My idea is to create a schema mapper dynamically and setting here)--> Dynamic writer or Featurewriter ..
At the same time i have to run through all the folders and then through zip files and set the data to one fgdb.
Requirement is.. Here shape files don't have consistent names..
1.zip
Folder-->
1.shp-->Point
2.shp-->Polyline
3.shp-->Polygon
2.zip
Folder-->
2.shp-->Point
2.shp-->Polyline
2.shp-->Polygon
Will go the FGDB.
XXXFeatureClass(Point)
XXXFeatureClass(Polyline)
XXXFeatureClass(Polygon)
Please help me on this...
Cheers,
Srikanth Dasari
Best answer by takashi
I agree with @TiaAtSafe. Basically your question should be resolved by this workflow, if I understood your requirement correctly.
However, if you need to modify attribute names of the source features according to the destination schema (definition of the set of attributes), some other processes would also be needed.
  • Dec 28, 2017 1:30 PM UTC
I suppose that the requirement is: the destination FGDB should have three feature classes for storing point features, line features, and polygon features, and you need to write all features read from Shapefile files in zip files into appropriate FGDB feature classes according to geometry type. Do I understand correctly?
  • Dec 28, 2017 5:13 PM UTC
Exactly.. Shape file names are not consistent to configure in any reader...
Please do the needful.
fmelizard
Forum|alt.badge.img+22
  • Dec 28, 2017 10:27 PM UTC
Hi @kanthsri74, have you had a chance to look at the GeometryFilter? It could help filter the features based on points, lines, polygons in the workspace.
  • Dec 29, 2017 3:22 PM UTC
  • Dec 29, 2017 8:36 PM UTC
Thanks for the response. I have used TestFilter transformer using Shape_Geometry field to seggregate into different feature classes.
Anyway, thank you
  • Dec 29, 2017 8:37 PM UTC
Anyway, thank you
