Name grouped feature-strings
  • Jan 23, 2018 8:10 AM UTC
  • 6 replies
  • 85 views
I'm creating strings from feature with the StringConcatenator. Now I would like to group the feature-strings by an attribute with the Sampler. How can I add in front of each feature-group an additional string with the group attribute?
Best answer by takashi
Hi @nindalf, if I understood the requirement correctly, this workflow could be a solution.
[Edited]
Source (CSV)
Feature,Attribute
1,A
10,B
2,A
9,B
3,A
8,B
4,A
7,B
5,A
6,B
Result (Text)
Group A
Feature 1 Attribute:A
Feature 2 Attribute:A
Feature 3 Attribute:A
Feature 4 Attribute:A
Feature 5 Attribute:A
Group B
Feature 6 Attribute:B
Feature 7 Attribute:B
Feature 8 Attribute:B
Feature 9 Attribute:B
Feature 10 Attribute:B
  • Jan 23, 2018 8:33 AM UTC
  • Is "'Feature 1 Attribute:A" a single concatenated string?
  • What result do you need to get after sampling?
  • Jan 23, 2018 8:39 AM UTC
From each feature I generate a string (one row) which include the attribute of the feature. I would like to group these strings to send them to the text writer in the correct order. Additionally, I would like to add the grouping attribute in front of each string group as shown in the picture.
  • Jan 23, 2018 8:46 AM UTC
Change the question. Originally (i.e. before string concatenation), what attributes did the features have?
  • Jan 23, 2018 9:21 AM UTC
I'm guessing as below.
The original features have two attributes called "Feature" and "Attribute" - "Feature" can store sequential number 1, 2, 3, ..; "Attribute" can store a group name: "A" or "B".
The requirement is:
  • sort the features by group name and number
  • concatenate the attribute values to create a single string "Feature <number> Attribute:<group name>"
  • insert new features containing a string "Group <group name>" before every first feature for each group
  • finally write the strings into a text file
Am I right?
If I was wrong, please clarify the conditions and requirements.
  • Jan 23, 2018 10:18 AM UTC
The requirement is:
Am I right?
This sounds right!
  • Jan 23, 2018 10:36 AM UTC
[Edited]
Source (CSV)
Feature,Attribute
1,A
10,B
2,A
9,B
3,A
8,B
4,A
7,B
5,A
6,B
Result (Text)
Group A
Group B
