MSWordGenerator and FME Cloud?
  • September 19, 2017
  • 64 views
Is it possible to use the MSWordGenerator transformer to out .docx via FME Cloud?
Best answer by stewartatsafe
HI. I just looked through the transformers and there is nothing Linux specific in there so it should run on FME Cloud no problems. It looks to basically create an xml file and then zip it up into a docx file. Safe didn't actually create these transformers, so if you have any specific questions about using the transformers then you might want to try asking the author directly by commenting on the item on FME Hub.
stewartatsafe
Forum|alt.badge.img+10
