Managing raster files from API request
  • Jun 25, 2024 9:39 PM UTC
  • 120 views
armando_amador
Forum|alt.badge.img+5
I have requested a raster file from an API (HERE Map Image API v3), and the response comes in the fashion of (I guess) base64 data.
I would like to have a way to transform such data and store it in proper folders.
Any idea?
Regards.
hkingsbury
Forum|alt.badge.img+73
  • Jun 26, 2024 3:51 AM UTC
Two transformers to look at will be the TextDecoder (can decoded the base64) and the AttributeFileWriter which can write the contents of an attribute to a file
armando_amador
Hi @hkingsbury, thanks for your help, it helped to show the way to unlock AI capabilities in FME 2024, using PythonCaller I asked to the AI and it provided this code:
import fme
import fmeobjects
class FeatureProcessor(object):
def __init__(self):
pass
def input(self, feature: fmeobjects.FMEFeature):
# Retrieve the _response_body attribute from the feature
response_body = feature.getAttribute('_response_body')
# Assuming response_body contains binary data for the raster
# Convert the binary data to a raster file
# This example saves the raster to a temporary file. Adjust the path as necessary.
raster_file_path = r'YOURFILEPATH\raster.tif'
with open(raster_file_path, 'wb') as file:
file.write(response_body)
# Optionally, set the path of the raster file as an attribute to the feature
feature.setAttribute('rasterFilePath', raster_file_path)
# Output the feature
self.pyoutput(feature)
This helped to convert my api _responsebody input data and then stored it into the specific path.
Sharing it to newbies in the future to have a nice way to solve this issue.
Regards!
hkingsbury
  • Jun 26, 2024 8:24 PM UTC
Nice job @armando_amador! Did you try the AttributeFileWriter? You’ll be able to achieve the same outcome without needing python
