LineCombiner and MRF2DJoiner seem not to work properly
  • Apr 4, 2018 2:47 PM UTC
  • 6 replies
  • 57 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I have a shapefile where some connected lines have to get connected and merged into one feature.
However, it seems like there is a problem in my use of LineCombiner and MRF2DJoiner.
Here is my shapefile :
https://drive.google.com/open?id=1Iwe0FDMePozczihABOvJ_PBlre7xRAis
Attached : a picture of a linear feature who has passed through the LineCombiner but still divided in 2 llines altough there are both connected.
Thank you.
  • Apr 4, 2018 3:28 PM UTC
Is it possible that there are minuscule rounding errors between the line connections?
Before the LineCombiner, try inserting a Snapper with a suitable tolerance, set snapping mode to "End point snapping" and see if that makes a difference.
lianaolianov
  • Apr 4, 2018 4:11 PM UTC
I tried so but it's not working
Lines are connected
  • Apr 4, 2018 4:13 PM UTC
Lines are connected
How are the lines oriented? Have you set "preserve original orientation = No" in the LineCombiner?
Have you set a Group By?
lianaolianov
  • Apr 4, 2018 4:20 PM UTC
I don't know how lines are oriented
I've tried preserve original orientation with yes and no
i didn't set a group by
here is my shapefile :
  • Apr 4, 2018 4:23 PM UTC
No sure why, but I'm unable to open the .rar file.
lianaolianov
  • Apr 4, 2018 5:03 PM UTC
Here is a zip file
lengthcalculator-mrfw-output-line.zip
