Is it possible to update a feature class in a fgdb with a dynamic writer?
  • Sep 22, 2021 10:32 AM UTC
  • 77 views
I have a dynamic workspace with a dynamic file geodatabase reader. I want to update some of the feature classes in the file geodatabase.
When I use a normal (=not dynamic) writer, it works. However, I would like to use a dynamic writer. But with the dynamic writer, I always get an error:
"Geodatabase Writer: Feature Class or Table 'd_y_n' must exist when Table Handling is set to 'Use Existing'" - I don't know where the 'd_y_n' comes from.
What am I doing wrong?
nielsgerrits
Forum|alt.badge.img+67
I believe this is a warning, not an error? What version FME do you use? Should be solved since 2018.1.
But I think you can just ignore it.
Thank you for your answer! Aha, my version is 2018.0... In that case it will work only with the next upgrade!?
