Invalid Transformer Parameters There are invalid parameter values in either the main workspace and/or embedded transformers.
  • May 23, 2017 5:53 AM UTC
  • 215 views
This has just popped up a workspace I've been working with for some weeks after making a series of adjustments. The problem is the message is too vague to track the issue down. The only qualifying statement is
 The invalid values are in: Main. Do you want to continue and run the workspace with the invalid values?
If I continue there's no obvious failure.
I presume Main is the whole of the workspace. That's not too helpful. I would have thought if the inconsistency could be detected then the target would be known.
How do I debug this? What am I looking for?
Thanks in advance.
  • May 23, 2017 7:31 AM UTC
I discovered the issue. During my edits I'd removed an extraneous link between two Transformers. As a result one transformer had fields that were no longer referenced. I cleaned up the links just by refreshing the field list. For future reference it looks like a red cog in the corner of a transformer is an indication of where this error is occurring. This red cog also appears in the Navigator pane under the Transformerrs
philippeb
Forum|alt.badge.img+23
  • Apr 11, 2018 6:58 PM UTC
Hi!
Do you know if there's a way to turn off this message?
