In XMLTemplater, is it possible to process attributes of an XML element through a distinct sub-template (i.e. through {fme:process-template(" ")} ) ?
jfd553
I convert input features to XML using XMLTemplater. Everything is fine as long it is done through the same sub-template. When I try to process some attributes (coordinates reading) by calling another sub-template it fails.
This sub-template works properly
**OBJECT Sub-Template**
{<object
  id="{fme:get-attribute("id")}"
  visible="{fme:get-attribute("visible")}"
  lon="{geom:get-y-coord()}"
  lat="{geom:get-x-coord()}" >
</object>}
This one, calling another sub-template, doesn't work.
{<object
  {fme:process-template("XY")} > Here is the syntax error: unexpected character "{" near line 4, column 5 .
</object>}
**XY Sub-Template**
{ lon="{geom:get-y-coord()}"
  lat="{geom:get-x-coord()}" }
I did try a lot of things but I still don't see what the problem is 😞
Thanks for any help...
Best answer by thijsknapen
I'm not entirely sure, but I think your issue might be related that you try to use an sub template for a set of XML attributes, and not for an XML document itself.
I guess the latter is a requirement for the XMLTemplator
thijsknapen
Forum|alt.badge.img+10
  • September 8, 2021
jfd553
  • September 13, 2021
Right, with some help (yours and FME support), I found that a sub-template deals only with complete xml elements. (i.e. must return a whole <element>… </element>. Thank.
