Create group ID based on conditions?
aron
Forum|alt.badge.img+16
The two lines below share the same end nodes and I want to give them a common group id for later processing. This is to be the step after a TopologyBuilder.
I thought this would be pretty simple, but have run aground. So how do I achieve this?
The geometris are to be left unchanged. I just want them to have a common “id” if they intersect at both ends.
The conditions for the ‘join’ are:
_from_node = _from_node AND _to_node = _to_node
OR
_from_node = _to_node AND _to_node = _from_node
Because sometimes the lines orient in different directions.
Best answer by takashi
Hi ​@aron ,
My idea is to create group ID by concatenating “_from_node” and “_to_node” with ascending order. The concept is shown below.
  • _node1 = If _from_node < _to_node then _from_node, Else _to_node
  • _node2 = If _from_node < _to_node then _to_node, Else _from_node
  • _group_id = @Value(_node1)_@Value(_node2)
Forum|alt.badge.img+22
  • April 4, 2025
Hi ​@aron ,
geomancer
Forum|alt.badge.img+47
  • April 4, 2025
A very simple and elegant solution!
If you want to, you can skip creating _node1 and _node2 by using _group_id =  @min(@Value(_from_node),@Value(_to_node))_@max(@Value(_from_node),@Value(_to_node))
Forum|alt.badge.img+31
  • April 4, 2025
Would the NetworkTopologyCalculator not do this for you?
aron
  • April 4, 2025
I believe that it would not get me where I want. There might be some trick with the NetworkTopologyCalculator that I dont know of, but when I have used it previously it gave me a ID for all the connected lines. I want to group only those that share the same start and end.
  • April 4, 2025
Ah too early in the morning for me, you’re actually looking for rings?
aron
  • April 4, 2025
I haven't thought about it that way, but two part rings would be an accurate description. AreaBuilder does not work for my use case though, it gives far to many false positives.
