If sentence not working
  • September 7, 2018
  • 10 views
Hallo! My problem is that i try to start a simple template with just an "Root Template". The code is like:
<OpenDRIVE>
    <header>revMajor="1" revMinor="1" name="" version="1.00"
    date="Fri Jul 27 14:52:00 2018"
    north="0.0000000000000000e+00" south="0.0000000000000000e+00"
    east="0.0000000000000000e+00" west="0.0000000000000000e+00"</header>
    if (fme:has-attribute("id"))
    then
        <road>
            r="road works"
        </road>
</OpenDRIVE>
The console give me that output:
XMLTemplater(XMLTemplaterFactory): The following error occurred near line 7, column 32 of the query:
XMLTemplater(XMLTemplaterFactory): invalid expression: syntax error, unexpected ExprSingle (missing comma "," between expressions?)
XMLTemplater(XMLTemplaterFactory): An error occurred while parsing the ROOT template
XMLTemplater(XMLTemplaterFactory): A fatal error has occurred. Check the logfile above for details
I have no idea why my if sentence doesn't work, i do completely the same as in this question described:
https://knowledge.safe.com/questions/40027/convert-json-to-xml.html
I hope anyone can help me pls.
Best answer by david_r
Try adding an empty else clause:
<OpenDRIVE>
    then
        <road>
            r="road works"
        </road>
    else ()
</OpenDRIVE>
  • September 7, 2018
<OpenDRIVE>
    then
        <road>
            r="road works"
        </road>
    else ()
</OpenDRIVE>
<OpenDRIVE>
    then
        <road>
            r="road works"
        </road>
    else ()
</OpenDRIVE>
Thx it works!
