I need to create one list of user names that are in multiple attribute fields.
  • September 9, 2021
  • 5 replies
  • 106 views
mbaer
  • September 9, 2021
@mbaer​ Can you use StringConcatenator? Or in AttributeCreator/AttributeManager the Text Editor
mbaer
  • September 9, 2021
Thank you for the reply. But that will not work because I need each user name to be a different entry in the list. All those option create a list of lists. I am passing it to a HTTPCaller as part of the url so each one needs to be in one list separately.
Forum|alt.badge.img+50
Can you elaborate a bit? Do you have a sample of your data?
f.kemminje
Forum|alt.badge.img+11
  • September 10, 2021
Use list builder, add all the attribute which has names. then print or write to a text file or excel.
I have attached one fmw file. which will print names in fme log window
name1, name2, name3, etc...
mbaer
I can not share the data but the format is the same as the attached table.
So there are multiple attributes that have different user ids in them and I need a single list that can be the input for the HTTPCaller that will return the full names of those users.
