I am trying to merge rows based on an attribute
I am trying to merge rows based on an attribute "LeasePage" to create one row. I have looked at all the examples and none quite match what I am trying to achieve. It is probably something simple I have missed.
I am using Attributecreate, AttributeExposer and Aggregate transformers to get to this stage and I have tried switching on the different choices to no avail :(
Forum|alt.badge.img+32
  • October 17, 2019
Aggregator group by LeasePage and choose merge incoming attributes under accumulation mode
  • October 17, 2019
Hi I am using the Aggregator as the last step and also using the above info
  • October 23, 2019
I figured it out. In the Aggregator transformer I used the concatenate and listed only the species I wanted. I removed the ',' from the separator and it worked
