html extractor mystery
  • April 25, 2019
  • 87 views
salvaleonrp
Forum|alt.badge.img+15
This is my web page:
http://solutions.arcgis.com/water/help/water-utility-network-configuration/DataDictionary/DataDictionary/
I want to extract the text value of <div class = "agOverview agDetails spacing "> and the transformer finds the class but for some reason any Tag Part/HTML Attribute I use that's on the Property page of Google Inspector results to null. I also tried the drop down options (Whole/Value), tag #text and the result for the transformer is a feature with null value. Any ideas?
Best answer by takashi
The HTMLExtractor with this setting extracts text values from all the "div" elements having "agOverview agDetails spacing" in "class" attribute value, and populates them into a list attribute.
See here to learn more about CSS Selector syntax: https://www.w3schools.com/cssref/css_selectors.asp
  • April 25, 2019
